Rugged, fast and compact, Verbatim's USB 3.0 External Solid State Drive (SSD) provides the latest in external data storage options. Compact, lightweight, credit card size enclosure, it is ideal for users that demand maximum performance in data storage devices.
With USB 3.0 connectivity Verbatim's USB 3.0 External SSDs handle large data transfers quickly - perfect for video editing, interchanging large amounts of data or maximizing gaming performance. It operates silently and features low power consumption for extending laptop battery life.
USB 3.0 is up to 10x faster than USB 2.0 based on the theoretical bus speed of 4.8 Gbps. USB 3.0 is 100% backwards compatible with USB 2.0.
- Verbatim Store 'n' Go External SSD - solid state drive - 128 GB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 128 GB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Rugged
- Power Source
- USB bus
- Enclosure Colour
- Sleek black
- 4.3 cm x 9 cm x 0.9 cm
- 42 g
- 2-year warranty
- Capacity
- 128 GB
- Interface
- USB 3.0
- Rugged
- 4.3 cm
- 9 cm
- 0.9 cm
- 42 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- OS Required
- Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7, Linux 2.4.0 or later
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB 3.0 cable - external - 18 cm
- Enclosure Colour
- Sleek black
- Limited warranty - 2 years
