Veho ZB-6 On-Ear Wireless Bluetooth Headphones
Quicklinx: D37CWS00 Mfr#: VEP-014-ZB6
Accessory Type: Headphones
Connectivity: Wireless
Colour: Black
34 in stock
£46.94 ex VAT
£56.32 inc VAT
Enjoy up to 24 hours of uninterrupted wireless music from a single charge, with the ZB-6 on-ear headphones from the Veho Z-Series audio range.
The Veho ZB-6’s feature low energy 4.1 Bluetooth connectivity, ideal for connecting up wirelessly to the Apple iPhone 7, iPhone 7 Plus, Android Smartphones or other Bluetooth devices such as, PC’s, tablets and MP3 players.
The 40mm acoustic drivers deliver a premium audio quality, with well-balanced mids and high fidelity treble, producing an enhanced listening experience. The Veho ZB-6’s also feature noise isolating technology, which means they’re are ideal for commuting, watching movies, the gym or for general everyday use.
Take voice calls and control your music’s track selection or volume thanks to the built-in microphone and remote control on the ear-cups. The Veho ZB-6’s also support voice commands for Siri and Google Now.
The built in 3.5mm auxiliary port make the ZB-6 headphones compatible with any standard AUX connections and will enable the ZB-6 to work as standard headphones when out of battery. The folding design makes them easy to store in your bag and allow you to take them anywhere you want.
Key Features
  • Built-in rechargeable battery allowing up to 24 hours continuous music playback
  • Connect via 4.1 Bluetooth for wireless listening or use optional 3.5mm aux jack
  • Well balanced mids and high fidelity treble delivering a premium audio experience
  • Noise isolating super soft ear cups and Tacton rubber touch for a stylish finish
  • Take voice calls and control your music with the multi-function on-ear controls.
Box Contents
  • Veho ZB-6 Bluetooth headphones
  • 120cm auxiliary cable with 3.5mm jack
  • Micro USB to USB-A charging cable
  • Multi lingual user manual (English, French, Spanish, German, Italian, Portuguese, Japanese & Chinese).
Veho ZB-6 - headphones with mic
Headphones - Bluetooth - wireless
Compatibility
iPhone, Android phone
Recommended Use
Portable electronics
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Radio Frequency Range
2.402 - 2.480GHz
Bluetooth Version
Bluetooth 4.1 EDR
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
Impedance
32 Ohm
Compatibility
Recommended Use
Max Operating Distance
10 m
Headphones
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.1 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
100 dB
Impedance
32 Ohm
Diaphragm
40 mm
Wireless Link
2.402 - 2.480GHz
Connector Type
Headphones (mini-phone stereo 3.5 mm)
Audio cable - 1.2 m
Micro-USB charging cable
Headphone battery rechargeable - Lithium Ion
380 mAh
Run Time (Up To)
24 hour(s)
Standby Time
250 hours
Recharge Time
3 hour(s)
Colour: Black
Brand: Veho
Price Range Ex VAT: 0 - 50
