The lightweight design and leather finish with super soft ear cups make the Z-4 headphones incredibly comfortable to wear for long periods. The fold flat design makes them easy to store in your bag and allow you to take them anywhere you want. The acoustic drivers deliver high clarity audio quality, which when mixed together with the powerful bass, produces a better listening experience. The Veho Z4's are ideal for commuting, watching movies, DJ sets, the gym or for general everyday use. The Veho Z-4's inline cable comes with a built-in microphone and remote control, perfect for making and taking calls or for simply changing the track or volume control.
- Veho Z-4 - headphones with mic
- Product Type
- Headphones - wired - 3.5 mm jack
- Compatibility
- iPhone, iPad, iPod, Android phone, Mac, Windows
- Recommended Use
- Portable electronics, computer
- Headphones Form Factor
- On-ear
- Foldable
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 106 dB
- Impedance
- 32 Ohm
- Product Type
- Compatibility
- 14.5 cm
- 18.5 cm
- 6.7 cm
- 150 g
- Headband Material
- Leather
- Recommended Use
Audio Output
- On-ear
- Foldable
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 106 dB
- Impedance
- 32 Ohm
- Diaphragm
- 50 mm
- In-Cord Volume Control
- Connector Type
- Headphones (mini-phone stereo 3.5 mm)
Cable
- Cable Length
- 1.2 m
- Cable Details
- Headphones cable - 1.2 cm
