Like all the other portable chargers in the Pebble range, the Ministick has a built-in USB output, so all you need to do is plug in your smartphone charging cable and you're ready to go. The Pebble Ministick has an 1800mAh capacity battery, which is enough to give your mobile device an emergency additional charge. Then simply recharge your Pebble Ministick via the micro USB port and the supplied charging cable ready for the next occasion you need a power boost.
The Pebble Ministick has a soft touch Tacton rubber finish, and also incorporates a handy loop, for either putting on a set of keys or attaching to rucksack/holdall. The 4 blue LED power indicators on the Ministick will also let you know how much charge your Pebble has, so when it's getting low, you will know to re-charge it. Compared to other power banks on the market, the Pebble Ministick emergency portable rechargeable battery is by far the most cost effective way of keeping your smartphone in power.
- Will charge most popular USB powered devices including smartphones, MP3 players, GPS and many more
- Will provide one full emergency charge for your smartphone or mobile device
- Soft 'Tacton' rubber touch finish with handy key loop for putting on your keys or keeping in your bag
- 4 blue LED power indicators let you know how much power your Pebble Ministick has and when it needs re-charging
- The most cost effective way to charge your smartphone or mobile device on the move
Box Contains
- 1 x Pebble Ministick 1800 mAh
- 1 x Micro USB Charging Cable
- Multi-lingual user manual
- Veho Pebble Ministick power bank - USB
- Product Type
- Power bank
- 10.25 cm x 2.25 cm
- 62 g
- Black
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 1 A
- Battery
- 1800 mAh
- Cables
- Micro-USB to USB cable
- Product Type
- Power bank
- 10.25 cm
- 2.25 cm
- 62 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 1 A
- Capacity
- 1800 mAh
- LED power meter, built-in key ring, Tacton rubber finish
- Included Accessories
- USB charging cable
- Cables Included
