Your basket is empty
Veho VCC-A017-UPM Universal Pole/Bar Mount for Muvi HD
Quicklinx: 7TSGWS00 Mfr#: VCC-A017-UPM
Universal pole/bar mount with tripod mount for Muvi and Muvi range
Veho VCC-A017-UPM Universal Pole/Bar Mount for Bikes, Roll Cages, Boat Rigging with Tripod Mount
- Fully adjustable bar/pole mount with 5cm x 4cm diameter
- Perfect for all parts of bike, car roll bars, boat rigging
- Ships with MUVI Waterproof case tripod mount
- Compatable with MUVI HD Range and MUVI Micro (Handlebar Mount Required)
The universal Pole/Bar mount is the most versatile mount and will work in conjunction with the mount fittings with the MUVI HD or the tripod mount for the Waterproof case. This mount is perfect for mounting anywhere on a bike, roll cage, boat rigging or anywhere where there is a bar or pole. Ships with tripod mount and is compatible with MUVI Micro and MUVI Atom (Appropriate WPC of Handlebar mount required)
Box Contains
Bar/Pole Mount
Tripos Mount
Veho Universal pole/bar mount - clampod
Clampod
Muvi HD
Clampod
Tripod
Supported Devices
Camcorder
Kit Content
Kit Content
(1) x clamp , (1) x tripod mount
Veho muvi HD
