Veho VAA-010 Triple USB 5V 5.1a Car charger
Quicklinx: BHLXWS00 Mfr#: VAA-010
Type: Charger
More than 50 in stock
£5.81 ex VAT
£6.97 inc VAT
Charge your smartphone, tablet or any other USB device simultaneously with the triple travel car charger from Veho. The Veho charger works with standard vehicle sockets and has 3 separate USB ports, meaning that not only can you charge more than one device at the same time, but the 2.1 A output will safely charge up your smartphone device quicker than any standard USB travel charger. As well as smartphones, the powerful output from the Veho will charge devices such as e-cigarettes, GPS, tablets, e-book readers, PDAs, portable speakers, or any other USB rechargeable device. The small, sleek aluminum design of the Veho in car charger means that it will look good in any car. The Veho charger is the must have accessory for anyone who spends a lot of time in their car, and is ideal for any short or long distance car travel journeys such as work commutes, school runs or car holidays. With built-in detection functionality to detect the correct device amperage and also safety features that will stop overheating, overcurrent and overcharging, your mobile device is protected whatever its specifications. Charging will automatically stop when your device is full.
Veho VAA-010 car battery charger - USB
Car battery charger
Space grey
Output Connector Type
Total 3: USB
12 - 18 V
Max Electric Current
5.1 A
Power Device Details
- 4 pin USB Type A - 5 V - 1 A , - 4 pin USB Type A - 5 V - 2 A , - 4 pin USB Type A - 5 V - 2.1 A
Car battery charger
Enclosure Colour
Space grey
12 - 18 V
Input Connectors
Automobile cigarette lighter
Output connectors
Total 3: 4 pin USB Type A
5.1 A
4 pin USB Type A - 5 V - 1 A , 4 pin USB Type A - 5 V - 2 A , 4 pin USB Type A - 5 V - 2.1 A
Overcharging protection, overheat protection, over-current protection, battery current detection
Type: Charger
Brand: Veho
Stock Status: In stock
