The V-1 features anti-reverse charging and over-charging protection with a helpful LED display indicator to prevent any damage to the batteries or the USB battery charger and show the charging status.
Charge your batteries anywhere thanks to the included USB-A to micro-USB cable, perfect for charging at home or at work through a USB mains plug or computer. Alternatively, you can charge your V-1 battery charger on the go through your laptop or a portable power banks.
The V-1 Pebble USB battery charger is the must have accessory E-Cigarettes, flashlight and other products that use 18650 or compatible batteries.
Designed in the UK, the Veho V-1 USB battery charger confirms to all safety marks such as CE, EMC and LVD.
The versatile V-1 USB battery charger is compatible with a wide variety of batteries, such as 18650, 10440, 14500, 14650, 16340, 16650, 17650, 17670, 18350, 18490, 18500, 18700, 22650, 20700, 21700, 22700, 25500, 26650 and 26700 batteries.
*Batteries not included
**Not compatible with rechargeable AA or AAA batteries
- Veho V1 battery charger
- Product Type
- Battery charger
- Voltage Required
- 5 V
- Cables
- Micro-USB to USB cable
- Product Type
- Battery charger
- Voltage Required
- 5 V
- Max Electric Current
- 2 A
- Reversed polarity protection circuit, LED indicator, short circuit protection, overcharging protection
Supported Battery
- Max Supported Qty
- 4
- Form Factor
- 18650
- Technology
- Lithium Ion
- Cables Included
- EMC, LVD
