With 2.4" LCD color screen and built in Lith-ion battery this scanner has true 'stand alone' capability. It also allows you to scan 110 negatives as well as the usual 35mm.
Convert all your old negatives and slides direct to SD Card. No PC or Mac Required, but also PC and Mac compatible. With added convenience of full colour 2.4" LCD screen. Comes with bundled 2GB SD.
Transfer 35mm slides and 35mm & 110mm negatives onto an SD card with the standalone VFS-008 Smartfix scanner.
- Veho VFS-008 Smartfix - film scanner (35 mm) - desktop - USB 2.0
- Film scanner (35 mm) - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CMOS
- Max Supported Document Size
- Film 135 (35mm)
- Interpolated Resolution
- 3600 dpi
- Supported Document Type
- Slides, film
- Battery
- 1 x Lithium Ion
- System Requirements
- Apple MacOS, Microsoft Windows 7
- 10 cm x 10 cm x 15 cm
- Interface Type
- USB 2.0
- Film 135 (35mm)
Scanner
- 3600 dpi
- CMOS
- Scanner Features
- Powered by USB port, 2.4" LCD screen
Media Handling
- Slides, film
- Supported Flash Memory Cards
- SD Memory Card
- USB 2.0
- Included Accessories
- 2 GB SD Memory Card
- RoHS
- Battery Installed
- 1 x Lithium Ion
- OS Required
- 10 cm
- 10 cm
- 15 cm
