Veho Slide & Negative Scanner for 35mm & 110 Instamatic Negatives
Quicklinx: 7KQKWS00 Mfr#: VFS-002m
The VFS-002M is Mac compatible and comes with 35mm & 110mm slide and negative trays. Convert your old memories onto your PC ready for editing, archiving, restoring or printing.
Transfer your old 35mm negative film and slides and 110mm instamatic negatives onto your PC/Notebook/Mac ready for editing, archiving or printing. A simple plug and play scanner with no driver to install and fast one touch scanning making it easy to bring those old pictures back to life. Perfect for restoring all those old cherished memories and moments back into the digital world and sharing by email or Facebook. If you want to remove redeye or enhance your image in anyway then simply use the bundled Arcsoft Mediaimpressions software. This is the first scanner to be capable of scanning 110mm negatives.
Veho VFS-002M Colourbright - film scanner (35 mm) - desktop - USB 2.0
Film scanner (35 mm) - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CMOS
Max Supported Document Size
Film 135 (35mm)
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
1400 dpi
Interpolated Resolution
1800 dpi x 3600 dpi
Supported Document Type
Slides, film
Microsoft Windows XP, Apple MacOS X 10.3.4 or later, Microsoft Windows Vista (32/64 bits)
9.3 cm x 7.7 cm x 10 cm
Interface Type
USB 2.0
Film 135 (35mm)
Scanner
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
1400 dpi
1800 dpi x 3600 dpi
CMOS
Scanner Features
Powered by USB port
Media Handling
Slides, film
USB 2.0
Plug and Play
Software Included
ArcSoft MediaImpression
9.3 cm
7.7 cm
10 cm
