Never misplace or lose your keys or smartphone again, thanks to the new SAEM S8 Reperio Bluetooth proximity key finder from Veho.
If you lose your SAEM S8 Reperio key fob, you can also track the last known location of the key fob using the iOS or Android Reperio app, which works alongside Google Maps to help locate your lost Reperio if you are outside of the Bluetooth range.
The SAEM S8 Reperio also has a camera mode function that will allow you to use the Reperio as a photo remote control for your smartphone to take a photo, using the camera on your Android or iOS smartphone, allowing you to take the perfect selfie.
The SAEM S8 Reperio has a built-in USB rechargeable battery, which will give you 320 hours of use, with only 2.5 hour charge time. The Reperio has Bluetooth 4.0 BLE, (Bluetooth Low Energy) which allows you to get the most out of the SAEM S8's battery life and gives extra range.
The patent design, which was designed in the UK, is the perfect accessory for anyone, such as students, travelers and even business users.
- Veho SAEM S8 Reperio Proximity Alarm/Finder - wireless key finder for mobile phone
- Product Type
- Wireless key finder
- Intended For
- Mobile phone
- Wireless Interface
- Bluetooth
- Battery
- 1 x rechargeable
- Run Time (Up To)
- 320 hours
- Package Content
- Mini-USB cable, Bluetooth finder
- Product Type
- Intended For
- Mobile phone
- Bluetooth 4.0
- Package Content
- Rechargeable Battery
- Rechargeable
- Required Qty
- 1
- Capacity
- 110 mAh
- Run Time (Up To)
- 320 hours
