Veho Saem S3 Ayrton Senna Bluetooth Car & Speaker Kit
Quicklinx: BHMFWS00 Mfr#: VBC-002-AS
Be safe whilst driving and taking that phone call with the SAEM S3 Ayrton Senna Bluetooth handsfree car kit and speaker.
The SAEM S3 handsfree speaker system is 3 products in 1. Firstly, when using in a car the SAEM S3 will allow you to make and receive phone calls handsfree preventing accidents and police action. The built-in AMS technology works by detecting human movement in the car so that the SAEM can automatically power on and off which means that the battery life can be extended way beyond other Bluetooth car kits.
The second function is the A2DP which allows you to wirelessly play music from your phone to the speaker meaning the SAEM S3 doubles up as a portable speaker you can take anywhere.
Lastly the SAEM S3 comes bundled with a USB, 5 V car adapter so you can not only charge the device in your car, you can charge any smartphone or tablet as well.
Veho SAEM S3 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Continuous Power
3 Watt
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - 3 Watt - active
Speaker battery rechargeable
11.8 cm x 6.2 cm x 0.99 cm
72 g
Hands-Free Function
Speaker System
Speaker Type
Active
Continuous Power
3 Watt
Amplifier
Integrated
Bluetooth 3.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
Transmission Range
10 m
Speaker System Details
Speaker Details
Driver Details
Speaker: full-range driver
Car power adapter, visor clip, micro-USB cable, pin badge
Power Source
Rechargeable
Run Time (Up To)
32 hours
11.8 cm
6.2 cm
0.99 cm
72 g
