Your basket is empty
Veho Professional Edition Muvi HD 1080p Mini Camcorder
Quicklinx: 8GNYWS00 Mfr#: VCC-005-MUVI-HDPRO
  • microSD Card
  • microSDHC Card
Designed for professional use the Muvi HD Pro comes complete with 8GB memory card, full 1080p video, wireless remote control, universal suction mount plus much more.
The Muvi HD Pro model also includes a self timer, noise activation, touch panel, digital zoom and ships with a 8GB MicroSD card and a 1400mah internal battery that will give 4hrs record time. As well as the rich technical specifications the Muvi also comes with a range of sports mounting clips, universal suction mount and accessories that enables you to record in almost any situation.
Veho muvi HD Pro - action camera
Action camera - 1080p - widescreen
Action Camera Type
Mountable
Memory Card Slot
microSD card
Sensor Resolution
5.0 MP
Effective Sensor Resolution
Photo: 5.0 MP
Lens System
F/2.5
Min Focus Distance
2.5 cm
Digital Zoom
3x
Display
LCD display - 1.5"
Supported Battery
1 x Li-ion rechargeable battery - 1400 mAh (included)
Composite video/audio, HDMI, USB 2.0
4.7 cm x 1.9 cm x 8 cm
82 g
Camcorder Sensor Resolution
5.0 MP
Effective Photo Resolution
5.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.5"
Digital Zoom
3x
Print Standard
DPOF support
Digital Video Format
H.264
Image Recording Format
JPEG
Exposure & White Balance
Light Sensitivity
ISO 400
Exposure Modes
Automatic
White Balance
Automatic
Lens System
F/2.5
Min Focus Distance
2.5 cm
Max View Angle
160 degree(s)
Additional Features
Additional Features
Built-in speaker, auto power save, date/time stamp, USB charging, sound activated recording, touch panel control
Action Camera Features
Camera Type
Mountable
Display
1.5" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , HDMI output , Composite video/audio output
Software
Software
Drivers & Utilities
Car window mount, spring clip, helmet mounting kit, sports mounting kit, IR remote control
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Included Memory Card
8 GB microSDHC
Video Capture
H.264 - 1280 x 720 - 30 fps
4.7 cm
1.9 cm
8 cm
82 g
