Veho ZS-2 Water Resistant Sports Earphones – Yellow/Black
Quicklinx: BHM3WS00 Mfr#: VEP-005-ZS2
These stereo earphones are small, lightweight and designed for the active lifestyle. They come in a water, rain and sweat resistant body with a cord and are IP64 rated, which means that these sports earphones will be protected from total dust ingress and waterspray from any direction. The cable features the popular flat flex anti-tangle durable cord system and the hook design to fit over the ears and is comfortable with almost any helmets and goggles / glasses. A comfortable non-slip rubber earbud ensures they fit perfectly in your ear during any vigorous workout. The acoustic drivers give you better base and crisper sound, so not only do they look good they sound great. These earphones are ideal for gym workouts, cycling, running, skiing, snowboarding, skateboarding and other indoor and outdoor sports activity.
Veho ZS-2 - earphones
Earphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
Style
Sports
Yellow/black
Headphones Form Factor
In-ear - over-the-ear mount
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
16 Ohm
1-year warranty
Style
Sports
Yellow/black
Recommended Use
Protection
Waterproof, sweat-resistant
Audio Output
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
16 Ohm
Diaphragm
10 mm
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1.2 m
Cable Details
Headphones cable - anti tangle - 1.2 cm
Limited warranty - 1 year
