Veho Pebble P-1 Pro Portable Power Bank with Dual USB/USB-C MFi
Quicklinx: DM60WS00 Mfr#: VPP-009-P1PRO
Marketing description is not available.
  • Powerhouse
    Superior quality lithium-ion cells, 10,400 mAh capacity with dual USB outputs to charge 2 devices simultaneously.
  • Surge protection
    Auto shut-off mode to protect against short circuit, over-current, over-charging and over-discharging.
  • Power indicator
    LED power indicator means you can keep a close eye on the exact capacity when charging your devices.
Veho Pebble P1 Pro power bank - USB
Power bank
7.8 cm x 2.55 cm x 11.5 cm
260 g
Output Connector Type
Total 2: USB - on cable: Micro-USB, Lightning
5 V
Voltage Provided
5 V
Max Electric Current
2.1 A
10400 mAh
Cables
Micro-USB to USB cable , Lightning to USB cable
Power bank
7.8 cm
2.55 cm
11.5 cm
260 g
5 V
Input Connectors
5 pin Micro-USB Type B, 24 pin USB-C
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B, Lightning
2.1 A
10400 mAh
LED power meter, short circuit protection, auto shut-off
Carrying pouch
