Veho Pebble Explorer 8400mAH Portable Battery Pack inc Lightning Cable
Quicklinx: D378WS00 Mfr#: VPP-006-MAP
The Pebble Explorer Pro has a large 8400mAh capacity and dual USB port designed to enable charging of 2 devices at any one time and includes a certified Apple MFi Lightning Cable.
With a 2.1A output the Pebble Explorer Pro is designed to charge tablets in the most efficient way. This means that your tablet power is replaced as quickly as possibly when you’re low on charge and away from a mains source.
Don’t worry if your smartphone is also low on charge because the Explorer’s dual port design means it’s capable of charging 2 devices at the same time. The powerful 8400mAh battery can give most tablets a complete full charge and most smartphones up to 5 charges.
The stylish blue LED power indicator means you can keep a close eye on the Explorer’s exact capacity when charging your devices and also when you are recharging your Explorer.
An 8 hour mains charge to the Explorer will give your portable devices hours of additional usage while you are away from the mains which makes it the perfect companion for camping, trekking, festivals as well as business users who easily drain their portable devices during a long busy day.
The Pebble Explorer Pro now includes an MFi Apple authorised Lightning cable, which is compatible with all the latest Apple iPhones and iPads.
Key Features
  • Powerful 8400mAh portable and rechargeable battery for tablets, smartphones and USB rechargeable devices
  • Dual 2.1 Amp USB outputs designed to charge tablets and smartphones fast and efficiently
  • Digital LED indicator giving exact percentage charge available and auto shutoff mode to protect against short circuit, over-current, over-charging, and over-discharging
  • 8 hour charge time will give weeks of portable battery life for multiple devices (iPads, iPods, Kindle, Samsung Galaxy, iPhones, smartphones, etc.)
  • MFi Apple authorised Lightning Cable included
Box Contents
  • Veho Pebble Explorer Pro Power Bank
  • Apple Authorised Lightning Cable
  • Carry Pouch
  • USB Charging Cable with mini USB/Micro USB/Dual Apple 30 Pin/Samsung Galaxy Tablet connectors
  • Multi lingual user manual (English, French, Spanish, German, Italian, Portuguese, Russian, Japanese & Chinese).
Veho Pebble Explorer Pro power bank
Power bank
7.5 cm x 9.2 cm x 2.3 cm
192 g
Output Connector Type
USB
5 V
Voltage Provided
5 V
8400 mAh
Cables
Lightning cable
Power bank
7.5 cm
9.2 cm
2.3 cm
192 g
5 V
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Max Electric Current
2.1 A
Short circuit protection, overcharging protection, overdischarging protection, surge protection, power LED Indicator, overcurrent protection
8400 mAh
Carrying pouch
Lightning cable
MFI
