The stylish Ayrton Senna Signature Collection Pebble Smartstick+ emergency portable battery pack charger for mobile devices has been enhanced with an increased 3000 mAh power supply, ergonomic re-design with protective port dust cap and handy clip on karabiner. Also includes limited edition signature Ayrton Senna collector's badge.
Charge your portable device on the move without the need for mains power. Small and light enough to carry around in your bag, or clip on your rucksack, the Ayrton Senna Signature Collection Pebble Smartstick+ portable emergency charger will provide your mobile device with over one additional charge, charging most popular devices including; Apple 30 pin, Blackberry and devices that use mini or micro USB.
The USB port on the Pebble Smartstick also allows you to charge your mobile device with the supplied manufacturer's cable.
The stylish design in a polished titanium gray incorporates a screw on cap to protect the Smartstick+ ports and also allow the Pebble karabiner to connect so you can hook onto anything.
For every unit sold Veho make a contribution to the Ayrton Senna Institute. Proceeds obtained from the licensing of the Ayrton Senna Institute brand is 100% invested in the Ayrton Senna Institute.
- Veho Pebble Ayrton Senna Smartstick+ power bank - USB
- Product Type
- Power bank
- 11.4 cm
- Diameter
- 2.1 cm
- 84 g
- Output Connector Type
- USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 500 mA
- Battery
- 3000 mAh
- Product Type
- Power bank
- Designed For
- Portable player, mobile phone
- 11.4 cm
- Diameter
- 2.1 cm
- 84 g
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- 500 mA
- Voltage Provided
- 3.7 V
- Capacity
- 3000 mAh
- Charging status indicator
- Included Accessories
- USB charging cable, carrying pouch, 3 connector tips, carabiner clip, connector cap, Ayrton Senna collector's badge
