Veho PEBBLE™ Verto Portable Charger 3700mAh - Grey / Black
Quicklinx: 93TLWS00 Mfr#: VPP-201-CG
Type: Rechargeable
16 in stock
£16.66 ex VAT
£19.99 inc VAT
Express delivery Order within the next 9 hours for delivery on Tuesday
The powerful Veho PEBBLE™ Verto portable battery charger is the must have accessory to keep all your mobile devices full of charge. It packs a 3700mAh which is over 2 times the regular battery of the Apple iPhone or Smartphone which means it will keep your devices on the go and you won't have to worry about running low on juice.
The PEBBLE™ Verto is perfect for festivals, camping trips, travelling abroad or as an emergency power pack for those busy days when your devices battery just can't keep up. The PEBBLE™ Verto will charge almost any portable device with connectors for the most popular Smartphones/USB charged devices/Veho MUVI™ and 360° range.
Simply charge your PEBBLE™ Verto up via USB and use the various adapters to keep all your mobile devices charged up. The PEBBLE™ Verto has a new smaller 'credit card' sized footprint perfectly portable and comes with 4 tips, charging cable and funky neoprene pouch to carry it all.
  • Will charge most popular mobile devices including Smartphones, Blackberry, Samsung, Nokia, Sony, gaming and USB charged devices
  • Mini credit card sized portable design with included neoprene carry case. Perfect for handbag or pocket (3.5in x 2.5in x 0.5in)
  • Auto shutoff mode to protect against short circuit, over-current, over-charging and over-discharging
  • Powerful 3700mAh portable battery charger (up to 1000 extra standby hours or 90 hrs extra music playback)
  • Just over 2 ½ full charges of most Smartphones
Veho Pebble Verto power bank
Power bank
6.5 cm x 9 cm x 1.4 cm
92.6 g
Grey
Output Connector Type
USB
5 V
Voltage Provided
5 V
- 3700 mAh
Standby Time
1000 h
Power bank
6.5 cm
9 cm
1.4 cm
92.6 g
Enclosure Colour
Grey
5 V
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Max Electric Current
1000 mA
Short circuit protection, overcharging protection, over-current protection, overdischarging protection
3700 mAh
Standby Time
1000 h
LED power meter, on/off button
USB charging cable, carrying pouch, 4 connector tips
Type: Rechargeable
Brand: Veho
Price Range Ex VAT: 0 - 50
