Your basket is empty
Veho Pebble™ Smartstick+ Emergency Portable Battery - Purple
Quicklinx: 9Z29WS00 Mfr#: VPP-004-GRP
The Pebble Smartstick+ emergency portable battery pack charger for mobile devices has been enhanced with an increased 2800 mAh power supply, ergonomic re-design with protective port dust cap and handy clip on karabiner.
Charge your portable device on the move without the need for mains power. Small and light enough to carry around in your bag, or clip on your rucksack, the Pebble Smartstick+ portable emergency charger will provide your mobile device with over one additional charge, charging most popular devices including; Apple 30-pin, Blackberry and devices that use mini or micro USB.
The USB port on the Pebble Smartstick also allows you to charge your mobile device with the supplied manufacturer's cable. The stylish design incorporates a screw on cap to protect the Smartstick+ ports and also allow the Pebble karabiner to connect so you can hook onto anything.
Veho Pebble Smartstick+ - external battery pack
External battery pack
11.4 cm
Diameter
2.1 cm
84 g
5 V
Voltage Provided
5 V
2800 mAh
11.4 cm
Diameter
2.1 cm
84 g
Enclosure Colour
Purple
5 V
Voltage Provided
5 V
Max Electric Current
500 mA
LED indicator
Voltage Provided
3.7 V
2800 mAh
USB charging cable, carrying pouch, 3 connector tips, connector cap
