Veho NPNG Muvi Super Micro DV Camcorder / Action Camera
Quicklinx: 8BH3WS00 Mfr#: VCC-004-ATOM-NPNG
  • microSDHC Card
  • microSD Card
The super tiny Muvi Atom redefines the world of small.
The Muvi Atom tiny size does not compromise quality recording at 640 x 480 at 30 FPS using Frame Rate Enhancement technology. The Atom also introduces the ability to take photo snapshots at 280 x 960 and comes bundled with the 2GB Micro SD card and sports mounting kit.
Veho muvi Atom - No Proof No Glory - camcorder - storage: flash card
Camcorder
Media Type
Flash card
Memory Card Slot
microSD card
Sensor Resolution
2.0 MP
Focus Adjustment
Focus free
Supported Battery
Li-ion rechargeable battery (included)
2 cm x 1.9 cm x 4 cm
Camcorder
Enclosure Colour
Camcorder Type
Consumer
Camcorder Sensor Resolution
2.0 MP
Sensor Qty
1 CMOS
Camcorder Media Type
Flash card
Optical Sensor Type
CMOS
Exposure & White Balance
Exposure Modes
Programme, automatic
Lens System
Focus Adjustment
Focus free
Max View Angle
80 degree(s)
Additional Features
Additional Features
Audio recording, auto power save, USB charging
Microphone
Microphone Operation Mode
Mono
Connector Type
USB
Software
Software
Drivers & Utilities
Neck strap, mounting hardware, carrying pouch, USB cable, spring clip, underwater housing, helmet mounting kit, magnet mount, handle bar mount
Underwater Use
Underwater Depth
Up to 30 m
Battery Type
Lithium Ion - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card
4 GB microSDHC
Image Storage
JPEG 1280 x 960
Video Capture
640 x 480 - 30 fps
2 cm
1.9 cm
4 cm
