Product
Brand
Veho Negative and Slide Scanner
Quicklinx: 744GWS00 Mfr#: VFS-008
With 2.4" LCD color screen and built in Lith-ion battery this scanner has true 'stand alone' capability. It also allows you to scan 110 negatives as well as the usual 35mm.
Veho VFS-008 Smartfix - film scanner (35 mm) - desktop - USB 2.0
Film scanner (35 mm) - desktop
Interface Type
USB 2.0
Scan Element Type
CMOS
Max Supported Document Size
Film 135 (35mm)
Interpolated Resolution
3600 dpi
Supported Document Type
Slides, film
1 x Lithium Ion
Apple MacOS, Microsoft Windows 2000/XP/Vista/7
10 cm x 10 cm x 15 cm
1 year warranty
Interface Type
USB 2.0
Film 135 (35mm)
Scanner
3600 dpi
Scan Element Type
CMOS
Scanner Features
Powered by USB port, 2.4" LCD screen
Media Handling
Slides, film
Supported Flash Memory Cards
SD Memory Card
USB 2.0
Slide holder, 2 GB SD Memory Card, 2 film holders
RoHS
Battery Installed
1 x Lithium Ion
10 cm
10 cm
15 cm
Limited warranty - 1 year
