Your basket is empty
Veho MUVI LONG MONOPOD
Quicklinx: 93SQWS00 Mfr#: VCC-A028-LMP
1 in stock
£21.48 ex VAT
£25.77 inc VAT
Standard delivery Delivered within 3-5 working days
The MUVI extra-long extendable monopod from Veho is the perfect monopod for action sports enthusiasts and prosumer filmers. With a super soft rubberized ergonomic grip and adjustable wrist leash it fits perfectly in the hand and will ensure that even if you wipe out you won't lose your camera.
Un-extended the MUVI monopod is 62 cm (24 inches) and using the 2 telescopic extenders with locking joints reaches to a huge 145 cm (57 inches). The MUVI monopod is fitted with a multi directional swivel and locking head and tripod mount which all amounts to self-filming and angles that other smaller monopods are just not capable of.
Veho MUVI Extra-Long Extendable - monopod
Monopod
Tripod Operating Height
62 cm - 145 cm
Muvi Atom, HD, HD10
Monopod
Folded Length
62 cm
Tripod
Tripod Legs Sections Qty
3
Tripod Legs Lock Type
Flip lock lever
Max Operating Height
145 cm
Min Operating Height
62 cm
Supported Devices
Camcorder, camera
Strap, mounting adapter
Veho muvi Atom, HD, HD10
Brand: Veho
Price Range Ex VAT: 0 - 50
