Veho MUVI LARGE POLE/BAR MOUNT
Quicklinx: 93SKWS00 Mfr#: VCC-A025-LPM
Attach your MUVI or MUVI HD camera to larger handle bars, roll bars, boat masts or any diameter tubes ranging from 16 mm to 58 mm. The Large Pole/Bar Mount is ideal for clamping almost anywhere and is completely compatible with the MUVI cradle mount that comes with your MUVI or MUVI HD camera or using with the tripod mount and waterproof case.
The Large Pole/Bar Mount is perfect for mounting ski/surf/snowboard racks, roll cages/bars, bike handlebars and bike frames. The Large Pole/Bar Mount ships with a tripod mount and 2 rubberized bands to help secure your mount and prevent damage so you can position your MUVI camera at any angle you want.
Veho MUVI Large Pole/Bar Mount support system - pole mount
Support system - pole mount
Muvi Atom, HD, HD10
Support system
Tripod
Support Type
Pole mount
Kit Content
Kit Content
(1) x pole mount , (1) x tripod adapter , (2) x rubber band
Veho muvi Atom, HD, HD10
