Capture 4K Ultra High Definition videos and shoot 12 MP photos with the Muvi K-Series K-2 Pro Wi-Fi handsfree camera from Veho.
The Muvi K-2 Pro features the super powerful XA-9 Hercules chipset, improving the performance of the Muvi K-2 Pro compared to its predecessor the XA-7 Achilles used on the previous K-2 models.
Capture Ultra HD 4K or 2.7K video with amazing quality and clarity. The K-2 Pro also allows you to film in Full HD at 60fps or 720p at 120fps, perfect for slow-motion play back.
For photos the Muvi K-2 Pro captures high quality 12 MP resolution photos and has a selection of photo modes for you to capture images the way you choose, including time lapse, high speed photo burst and 180° rollover mode. The built-in G-sensor auto-start will set your Muvi K-2 Pro to start recording on a change of gravity.
- Veho muvi K-Series K-2 Pro - action camera
- Product Type
- Action camera - 4K
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 12.0 MP
- Max Video Resolution
- 3840 x 2160
- Lens System
- Wide-angle lens f/2.8
- Focus Adjustment
- Focus free
- Digital Zoom
- 10x
- Display
- LCD display
- Supported Battery
- Li-ion rechargeable battery - 1500 mAh (included)
- Interface
- HDMI, USB 2.0
- Product Type
- Camcorder Type
- Wearable
- Camcorder Sensor Resolution
- 12.0 MP
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Frame Rate (Max Resolution)
- 15 fps
- Digital Zoom
- 10x
- 3840 x 2160
- Interface
- HDMI, USB 2.0, Wireless LAN
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Wide-angle lens f/2.8 - wide angle
- Focus Adjustment
- Focus free
- Max View Angle
- 100 degree(s)
Additional Features
- Continuous Shooting Speed
- 8 frames per second, 3 frames per second, 6 frames per second
- Additional Features
- Audio recording, auto power save, date/time stamp, interval shooting mode, USB charging, Time-Lapse recording, Auto REC, Loop recording, Mirror Upside Down
Action Camera Features
- Camera Type
- Mountable
- Time-Lapse recording
Tripod Mount
- Connection Point
- 1/4" socket
Display
- LCD display
- Display Form Factor
- Detachable
- Touch Screen
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , HDMI output (19 pin micro HDMI Type D)
- Included Accessories
- Tripod adapter, silicone case (black), protective case, USB charging cable, curved adhesive mount, flat adhesive mount, right angle mount, CMOS protector
- Protection
- Weatherproof
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Video recording - 3 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 64 GB
- Video Capture
- 3840 x 2160 - 15 fps , 1920 x 1080 p - 60 fps , 1280 x 720 p - 120 fps
