Your basket is empty
Veho MUVI K2 4K Pro Action Cam
Quicklinx: C8N8WS00 Mfr#: VCC-007-K2PRO
Capture 4K Ultra High Definition videos and shoot 12 MP photos with the Muvi K-Series K-2 Pro Wi-Fi handsfree camera from Veho.
The Muvi K-2 Pro features the super powerful XA-9 Hercules chipset, improving the performance of the Muvi K-2 Pro compared to its predecessor the XA-7 Achilles used on the previous K-2 models.
Capture Ultra HD 4K or 2.7K video with amazing quality and clarity. The K-2 Pro also allows you to film in Full HD at 60fps or 720p at 120fps, perfect for slow-motion play back.
For photos the Muvi K-2 Pro captures high quality 12 MP resolution photos and has a selection of photo modes for you to capture images the way you choose, including time lapse, high speed photo burst and 180° rollover mode. The built-in G-sensor auto-start will set your Muvi K-2 Pro to start recording on a change of gravity.
Veho muvi K-Series K-2 Pro - action camera
Action camera - 4K - widescreen
Action Camera Type
Mountable
Memory Card Slot
microSD card
Wireless Interface
Wi-Fi
Sensor Resolution
12.0 MP
Max Video Resolution
3840 x 2160
Lens System
Wide-angle lens f/2.8
Focus Adjustment
Focus free
Digital Zoom
10x
Display
LCD display
Supported Battery
1 x Li-ion rechargeable battery - 1500 mAh (included)
HDMI, USB 2.0
Action camera - 4K
Camcorder Sensor Resolution
12.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Digital Zoom
10x
3840 x 2160
HDMI, USB 2.0, Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Wide-angle lens f/2.8 - wide angle
Focus Adjustment
Focus free
Max View Angle
100 degree(s)
Additional Features
Continuous Shooting Speed
8 frames per second, 3 frames per second, 6 frames per second
Additional Features
Audio recording, auto power save, date/time stamp, interval shooting mode, USB charging, Time-Lapse recording, Auto REC, Loop recording, Mirror Upside Down
Action Camera Features
Camera Type
Mountable
Tripod Mount
Connection Point
1/4" socket
Display
LCD display
Display Form Factor
Detachable
Touch Screen
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , HDMI output (19 pin micro HDMI Type D)
Tripod adapter, silicone case (black), protective case, USB charging cable, curved adhesive mount, flat adhesive mount, right angle mount, CMOS protector
Protection
Weatherproof
Details
Battery Life Details
Video recording - 3 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Memory Card Max Supported Size
64 GB
Video Capture
3840 x 2160 - 15 fps , 1920 x 1080 p - 60 fps , 1280 x 720 p - 120 fps
