The MUVI K1 records high definition 1080p video at 30 fps, as well as 720p at 60 fps using the MUVI XA-5 Theseus chipset and has a choice of bit rate default being 16 mbit/s. As well as capturing amazing high definition footage The K1 captures photography stills at 8, 12 or 16 mega pixel, and comes equipped with photo burst mode that allows you to take up to 10 photos per second, which is perfect for trying to achieve the perfect action shot.
Additional features include 180° degree rollover which means if you are mounting your K-Series upside down the footage plays back the correct way up and G-sensor auto-start which allows you to set your MUVI to start recording on a change of gravity.
- Veho muvi K-Series K-1 - action camera
- Product Type
- Action camera - 1080p
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Sensors
- G-sensor
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 16.0 MP
- Lens System
- Wide-angle lens f/2.7
- Focus Adjustment
- Focus free
- Digital Zoom
- 10x
- Supported Battery
- Li-ion rechargeable battery - 1500 mAh (included)
- 6 cm x 4 cm x 2.3 cm
- Product Type
- Camcorder Type
- Wearable
- Camcorder Sensor Resolution
- 16.0 MP
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Digital Zoom
- 10x
- Sensors
- G-sensor
- Interface
- Wireless LAN
- Connectivity Features
- Remote control via mobile devices
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Focus Adjustment
- Focus free
- Max View Angle
- 140 degree(s)
Additional Features
- Additional Features
- Audio recording, auto power save, date/time stamp, interval shooting mode, USB charging, Time-Lapse recording, Auto REC, Loop recording, Mirror Upside Down
Action Camera Features
- Camera Type
- Mountable
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , HDMI output (19 pin micro HDMI Type D)
- Included Accessories
- Tripod adapter, underwater housing, USB charging cable, flat adhesive mount, right angle mount, flat touch fastener mount
- Underwater Use
- Underwater Depth
- Up to 60 m
- Battery Type
- Lithium Ion - manufacturer-specific
- Details
- Battery Life Details
- Video recording - 4 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- 1920 x 1080 - 30 fps - 16Mbps , 1280 x 720 - 60 fps - 16Mbps
- 6 cm
- 4 cm
- 2.3 cm
