Product
Veho MUVI EXTENDED POLE/BAR MOUNT
Quicklinx: 93SMWS00 Mfr#: VCC-A026-EPM
£6.08 ex VAT
£7.29 inc VAT
The MUVI Extended Pole Mount is designed to give users a better field of vision which is ideal for self-portrait filming with the help of the strong and robust extended arm built to any tube diameter ranging between 0.9 mm-23 mm.
The MUVI Extended Pole Mount has 2 ratchet pivots that are fully adjustable to allow you to angle your MUVI or MUVI HD any way you want. The MUVI Extended Pole Mount comes with a tripod mount but is also compatible with the cradle mount that comes with your MUVI or MUVI HD camera. It can be mounted anywhere from a bike frame or handlebars to car roll bar or cages. The mount is also ideal for motorbikes for viewing over the wind deflector to ensure that you don't compromise on quality of the footage.
Veho MUVI Extended Pole/Bar Mount - support system - bar mount
Support system - bar mount
Placing / Mounting
Handlebar, pole mount
Muvi Atom, HD, HD10
Support system
Tripod
Placing / Mounting
Supported Devices
Action camera
Support Type
Bar mount
Kit Content
Kit Content
(1) x handlebar mount , (1) x tripod adapter , (2) x rubber band
Veho muvi Atom, HD, HD10
Brand: Veho
Price Range Ex VAT: 0 - 50
