Veho Muvi Drivecam Quad HD Dashcam with GPS, Wifi and App
Quicklinx: F5XHWS00 Mfr#: VDC-001-KZ-1-F
£170.87 ex VAT
£205.04 inc VAT
The Muvi Drivecam with GPS tracking captures your journey in 1080p HD footage that can be viewed, via the App, on your smartphone, tablet or PC. Fully equipped with motion detection for automatic start/stop recording and a G-Force sensor, so should your car be involved in a collision, your files will be automatically protected.
HD QUALITY
Quad-HD video quality 1080p@60fps
GPS TRACKING
GPS tracking with route mapping software
AUTO START/STOP
Automatically turns on and starts recording when driving, stops when you turn the engine off
DEDICATED APP
Reviewed footage via the App, on your smartphone or tablet
MEMORY
Micro SDHC up to 128GB, not included
Veho muvi VDC-001-KZ1-F - dashboard camera
Dashboard camera - 1080p - widescreen
Memory Card Slot
microSD card
Sensors
Motion sensor
Wireless Interface
Wi-Fi
Sensor Resolution
2.13 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens f/2.0
Focus Adjustment
Focus free
Display
LCD display - 3"
Real-Time Locations
GPS
Incident Detection
G-Sensor
Supported Battery
1 x 900 mAh
11.44 cm x 3.7 cm x 7.19 cm
Camcorder Sensor Resolution
2.13 MP
Sensor Qty
1 CMOS
Widescreen Video Capture
Optical Sensor Type
Exmor R CMOS
Optical Sensor Size
1/2.8"
Frame Rate (Max Resolution)
60 fps
ISO (Max)
12800
Navigation
GPS receiver
Sensors
Motion sensor
Digital Video Format
H.264
1920 x 1080
IEEE 802.11b/g/n
Connectivity Features
Video playback via mobile device
Lens System
Focus Adjustment
Focus free
Max View Angle
120 degree(s)
Lens Construction
6 elements
Additional Features
Additional Features
Built-in speaker, Wide Dynamic Range (WDR), STARVIS sensor
Dashboard Camera Features
Real-Time Locations
GPS
Incident Detection
G-Sensor
WDR technology
Display
3" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Car power adapter, windshield mount
Battery Type
Manufacturer-specific
Details
1 x 900 mAh
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Memory Card Max Supported Size
128 GB
Video Capture
H.264 - 1920 x 1080 p - 60 fps
11.44 cm
3.7 cm
7.19 cm
Type: Dashboard camera
Brand: Veho
Price Range Ex VAT: 150 - 300
