Your basket is empty
Veho MUVI 3M FLAT STICKY BRACKETS
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 93SRWS00 Mfr#: VCC-A029-3M
Pack of 3 x MUVI 3M Flat Adhesive Mounts for use with your MUVI or MUVI HD camcorder. These mounts allow you to mount your MUVI camcorder securely to any flat surface. They will hold your camcorder securely in place but can easily be removed by applying heat, such as using a hair dryer.
Veho MUVI 3M Flat Adhesive Mounts - support system - adhesive mount
Support system - adhesive mount
Muvi Atom, HD, HD10, Pro DV
Support system
Tripod
Supported Devices
Action camera
Support Type
Adhesive mount
Kit Content
Kit Content
(3) x adhesive mounting base
Veho muvi Atom, HD, HD10, Pro DV
