The incredibly powerful M10 wireless speaker from Veho is designed to fill the entire room with sound, thanks to its unique design. Aside from the iconic lifestyle design, the bass and treble drivers deliver clean, crisp and powerful sound. Stream your music wirelessly by connecting your wireless Bluetooth device, such as a smartphone, tablet or MP3 player.
- Veho M-10 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- 2-way - active
- Continuous Power
- 60 Watt
- Frequency Response
- 40 - 19000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Speaker Details
- Speaker - stereo x 2 - 30 Watt - 40 - 19000 Hz - <2% THD - 4 Ohm - active
- Battery
- Speaker battery rechargeable - lithium
- 28.2 cm x 16.7 cm x 29.3 cm
- 2.903 kg
- Product Type
Speaker System
- Speaker Type
- 2-way - active
- Continuous Power
- 60 Watt
- 40 - 19000 Hz
- Signal-To-Noise Ratio
- 85 dB
- Amplifier
- Integrated
- Bluetooth 4.0, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Transmission Range
- 10 m
- Controls
- Volume
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 30 Watt - 40 - 19000 Hz CFR - <2% THD - 4 Ohm - active
- Driver Details
- Speaker: 2 x tweeter driver , Speaker: 2 x bass driver
- Connector Type
- Audio line-in (mini-phone 3.5mm)
- Included Accessories
- Power adapter
- Rechargeable - lithium
- Capacity (Ah)
- 2200 mAh
- Run Time (Up To)
- 9 hours
- Recharge Time
- 4 hours
- 28.2 cm
- 16.7 cm
- 29.3 cm
- 2.903 kg
