Product
Veho M10 Wireless Lifestyle Portable Bluetooth Speaker
Quicklinx: CKDMWS00 Mfr#: VSS-016-M10
Speaker Type: Speaker
Connection: Wired, Wireless
25 in stock
£110.98 ex VAT
£133.17 inc VAT
The incredibly powerful M10 wireless speaker from Veho is designed to fill the entire room with sound, thanks to its unique design. Aside from the iconic lifestyle design, the bass and treble drivers deliver clean, crisp and powerful sound. Stream your music wirelessly by connecting your wireless Bluetooth device, such as a smartphone, tablet or MP3 player.
Veho M10 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
2-way - active
Nominal Output Power
60 Watt
Frequency Response
40 - 19000 Hz
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo - 2 x 30 Watt - 40 - 19000 Hz - <2% THD - 4 Ohm - active
Speaker battery rechargeable - lithium
28.2 cm x 16.7 cm x 29.3 cm
2.903 kg
Speaker System
Speaker Type
2-way - active
60 Watt
Frequency Response
40 - 19000 Hz
Signal-To-Noise Ratio
85 dB
Amplifier
Integrated
Bluetooth 4.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Controls
Volume
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x tweeter driver , Speaker: 2 x bass driver
Connector Type
Audio line-in (mini-phone 3.5mm)
Power adapter
Rechargeable - lithium
2200 mAh
Run Time (Up To)
9 hours
Recharge Time
4 hours
28.2 cm
16.7 cm
29.3 cm
2.903 kg
Connection: Wired
Connection: Wireless
Brand: Veho
Price Range Ex VAT: 100 - 150
