Veho Kasa Bluetooth Smart LED Light Strip - 3m/9.8ft
Quicklinx: CV95WS00 Mfr#: VKL-001-3M
Type: Light strip
Compatible With: [N/A]
44 in stock
£17.69 ex VAT
£21.22 inc VAT
Enjoy low energy adaptive lighting with the Kasa smart lighting Bluetooth wireless LED light strip. Automate your home lighting wirelessly through the Kasa App for iOS and Android devices.
The Kasa smart lighting Bluetooth LED light strip is an adaptive 3m (9.8ft) strip of LED low energy lighting with 3M sticky back adhesive that allows you to backlight, downlight or uplight to create spectacular looking home or commercial interiors. Adapt your 3m (9.8ft) Kasa LED light strip to a length of your choice by using the safety cutting lines. The Kasa LED light strip will give you long hours of adaptive low energy lighting.
In conjunction with the Kasa smart lighting bulbs and the App for iOS and Android devices, you can enable a world of adaptive and creative lighting while automating your home lighting through the power of your smartphone or tablet. With white or yellow light hue and 16 million dimmable colors available, you can preset groups of rooms or moods so that you can control and adapt the lighting of your home environment at the touch of your smartphone or tablet. Using the Kasa lighting App you can schedule a 24/7, 365 day schedule of lighting for home and even choose to dim your lights by schedule or turn your lights out by countdown, which is great for young children or when you are leaving the house for an evening.
Veho Kasa - light strip - LED
Light strip
Light Bulb Type
LED
Image Colour Disclaimer
The displayed product image may be a different colour
Built-in LED Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Dimmable
AC 220 - 240 V
Frequency Required
50 Hz
Light strip
Auto power off, wireless, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth 4.0, 3M adhesive tape mounting
Light Bulb
LED
Built-in LED Lamp
A+
16 million colours
Dimmable
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 Hz
Power adapter (UK), power adapter (EU), power adapter (US), power adapter (AUS)
Length
3 m
Type: Light strip
Brand: Veho
Price Range Ex VAT: 0 - 50
