Enjoy low energy adaptive lighting with the Kasa smart lighting Bluetooth wireless LED bulbs. Automate your home lighting wirelessly through the Kasa app for iOS and Android.
The Kasa smart lighting B22 Bluetooth 7.5 watts (40 watts converted) LED bulb will give you 15,000 hours of adaptive low energy lighting. Kasa Bluetooth bulbs have a cost efficient life expectancy of 15 years when used 3 - 4 hours per day.
In conjunction with the Kasa smart lighting app for iOS and Android you can enable a world of adaptive and creative lighting while automating you home lighting through the power of your smartphone or tablet.
With white or yellow light hue and 16 million dimmable colours available, you can preset groups of rooms or moods so that you can control and adapt the lighting of your home environment at the touch of your smartphone or tablet.
Using the Kasa Lighting app you can schedule a 24/7, 365 day schedule of lighting for home and even choose to dim your lights by schedule or turn your lights out by countdown, which is great for young children or when you are leaving the house for an evening.
Currently not compatible with Amazon Echo / Echo Dot (Alexa).
Key Features
Low energy cost efficient LED adaptive lighting with 15 year life expectancy
Control up to 32 units automatically or by the touch of an iOS or Android smartphone or tablet
Dimmable app controlled adaptive lighting with 16 million colours to choose from
24/7, 365 day app scheduling to automatically control your home lighting environment
Kasa scheduling countdown feature allows you to automatically turn off lights at night time or when you are leaving the home
Create room and mood presets to group Kasa lighting and change mood lighting to suit your environment of activity
Box Contents
Kasa Bluetooth Smart Lighting LED Bayonet Cap B22 Bulb
Quick Start Guide
Product Manual
- Veho Kasa - LED light bulb - B22 - 7.5 W - 16 million colours
- Light Source Type
- LED light bulb
- Socket Type
- B22
- Wattage
- 7.5 W
- Wattage Equivalent
- 40 W
- Energy Efficiency Class
- A+
- Colour of Illumination
- Luminous Power
- 600 lumens
- Dimmable
- Communications Technology
- Bluetooth Low Energy (LE)
- Voltage Required
- AC 100 - 245 V
- Frequency Required
- 50/60 Hz
Light Source
- LED light bulb
- Socket Type
- B22
- Wattage
- 7.5 W
- 40 W
- A+
- Luminous Power
- 600 lumens
- Dimmable
- Lifetime
- 15000 hours
- Android compatible, iOS compatible, controlled via Bluetooth 4.0 Low Energy, remote controlled
Power Requirements
- Voltage Required
- AC 100 - 245 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Type
- Product-to-product
- Diameter
- 60 mm
- Length
- 112 mm
