Turn it up and enjoy audio with the V7 SP2500. Ideal for desktop computers and laptops alike, this compact speaker system delivers clear highs and lows in a glossy sleek, stylish design. The speakers connect easily to any computer, just plug them into a USB port and you're ready to go. The SP2500 will dress up any desktop work-space with great sound and a compact, sleek design. The V7 SP2500 speaker system delivers rich, crystal-clear sound, and is incredibly easy to setup and use, making this speaker system a must have.
- V7 SP2500 - speakers - for PC
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- Active
- Nominal Output Power (Total)
- 10 Watt
- Frequency Response
- 100 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x speaker 5 Watt - 100 - 20000 Hz - 10 kOhm
- Black
- Power Options
- USB powered
- 9.8 cm x 7.1 cm x 20 cm
- 475 g
- 2-year warranty
- Product Type
- Speakers - for PC
- Enclosure Colour
- Black
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 10 Watt
- 100 - 20000 Hz
- Signal-To-Noise Ratio
- 58 dB
- Amplifier
- Integrated
- Recommended Placing
- Table-top
- Controls
- Power on/off, volume
- Headphone Output Jack
- Interface Type
- USB
- Speakers Included
- 2 x speaker - 5 Watt - 100 - 20000 Hz - 10 kOhm - table-top - wired
- Driver Details
- Speaker: full-range driver
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Audio line-in (mini-phone stereo 3.5 mm) , USB (4 PIN USB Type A)
- FCC, RoHS
- Power Source
- USB
- Options
- USB powered
- 9.8 cm
- 7.1 cm
- 20 cm
- 475 g
- Limited warranty - 2 years
