Your basket is empty
V7 Stylus Pen Copper - Red
Quicklinx: BCLGWS00 Mfr#: ST2000-RED-10E
The V7 stylus pen is the perfect solution to avoid fingerprints on your capacitive touchscreen devices. Its balanced weight feels like a fine pen in your hand and is perfect for writing and casual drawing directly on your tablet or mobile phone. The barrel of the stylus is manufactured out of carbon fiber, adding strength and style. The rubber tip glides smoothly over any tablet screen so you can seamlessly jot down notes and illustrations. The pocket clip is sized to attach easily and securely to a folio cover. Whether you're in the office, at home or out and about, it's the fingerless way to navigate, input or sketch whatever you want on your touchscreen device.
V7 - stylus
Stylus
Intended for
Mobile phone, tablet
Stylus
Intended for
Red
