Turn it up and enjoy an incredible audio with the V7 SP2000. Ideal for desktop computers and laptops alike, this compact speaker system delivers clear highs and lows in a glossy sleek, stylish design. The speakers connect easily to any computer, just plug them into a USB port and you're ready to go. The SP2000 will dress up any desktop workspace with great sound and a compact, sleek design. The V7 SP2000 speaker system delivers rich, crystal-clear sound, and is incredibly easy to setup and use, making this speaker system a must-have.
- V7 SP2000 - speakers - for PC
- Product Type
- Speakers - for PC
- System Components
- 2 speakers
- Speaker Type
- Active
- Nominal Output Power (Total)
- 1 Watt
- Amplifier
- Integrated
- Speaker System Details
- 2 x speaker 0.5 Watt
- Black
- Power Options
- USB powered
- 3.5 cm x 7 cm x 17.5 cm
- 250 g
- 2-year warranty
- Product Type
- Speakers - for PC
- Enclosure Colour
- Black
Speaker System
- System Components
- 2 speakers
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 1 Watt
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Controls
- Volume
- Speakers Included
- 2 x speaker - 0.5 Watt - wired
- Driver Details
- Speaker: full-range driver - 1.97"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Power Source
- AC power adapter
- Options
- USB powered
- 3.5 cm
- 7 cm
- 17.5 cm
- 250 g
- Limited warranty - 2 years
