Your basket is empty
V7 Stero Speaker System USB 2.0
Quicklinx: BJGFWS00 Mfr#: SP2000-USB-1EC
Turn it up and enjoy an incredible audio with the V7 SP2000. Ideal for desktop computers and laptops alike, this compact speaker system delivers clear highs and lows in a glossy sleek, stylish design. The speakers connect easily to any computer, just plug them into a USB port and you're ready to go. The SP2000 will dress up any desktop workspace with great sound and a compact, sleek design. The V7 SP2000 speaker system delivers rich, crystal-clear sound, and is incredibly easy to setup and use, making this speaker system a must-have.
V7 SP2000 - speakers - for PC
Speakers - for PC
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
1 Watt
Amplifier
Integrated
Speaker System Details
2 x speaker 0.5 Watt
Power Options
USB powered
3.5 cm x 7 cm x 17.5 cm
250 g
2 years warranty
Speakers - for PC
Enclosure Colour
Speaker System
System Components
2 speakers
Speaker Type
Active
1 Watt
Signal-To-Noise Ratio
70 dB
Amplifier
Integrated
Controls
Volume
Speakers Included
2 x speaker - 0.5 Watt - wired
Driver Details
Speaker: full-range driver - 1.97"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Power Source
AC power adapter
Options
USB powered
3.5 cm
7 cm
17.5 cm
250 g
