The V7 USB portable power bank provides 6600 mAh of reliable and easy to use transportable power for recharging your mobile devices including: iPhone, iPad and iPod, tablet PC's, Smart phones and other mobile devices with a micro USB connection. Four LED indicator lights show you the power level and charging status. It even has a built in super bright LED flashlight. While charging your devices it monitors and protects against over voltages, short circuits and over currents. In today's mobile technology dependent society transportable reliable reserve power is essential to insure you're never left in the dark.
- V7 power bank Li-Ion
- Product Type
- Power bank
- 9.9 cm x 6.1 cm x 2.3 cm
- 190 g
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Battery
- Lithium Ion 6600 mAh
- Cables
- Micro-USB to USB cable
- 1 year warranty
- Product Type
- Power bank
- 9.9 cm
- 6.1 cm
- 2.3 cm
- 190 g
- Enclosure Colour
- White
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- Max Electric Current
- 2.1 A
- LED indicator, short circuit protection, overcharging protection, over-current protection, built-in flashlight, overdischarging protection
- Technology
- Lithium Ion
- Capacity
- 6600 mAh
- Recharge Time
- 7 hour(s)
- Max Recharge Cycles
- 300
- LED power meter
- Cables Included
- FCC, RoHS
- Limited warranty - 1 year
