Your basket is empty
V7 Powerbank 6600MA LI-ION - Black
Quicklinx: BFL1WS00 Mfr#: PB6600-2-BLK-20E
The V7 USB portable power bank provides 6600mAh of reliable and easy to use transportable power for recharging your mobile devices including: iPhone, iPad and iPod, tablet PC's, Smart phones and other mobile devices with a micro USB connection. Four LED indicator lights show you the power level and charging status. It even has a built in super bright LED flashlight. While charging your devices it monitors and protects against over voltages, short circuits and over currents. In today's mobile technology dependent society transportable reliable reserve power is essential to insure you're never left in the dark.
V7 power bank - Li-Ion
Power bank
6.1 cm x 9.9 cm x 2.3 cm
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Lithium Ion 6600 mAh
1 year warranty
Power bank
6.1 cm
9.9 cm
2.3 cm
Enclosure Colour
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2.1 A
LED indicator, short circuit protection, overcharging protection, over-current protection, built-in flashlight, overdischarging protection
Lithium Ion
6600 mAh
Recharge Time
8 hour(s)
LED power meter
Micro-USB to USB cable
FCC, RoHS
Limited warranty - 1 year
