The MV3030-USB-5EB USB optical mouse fits in the palm of your hand and has a retractable cord making it perfect for the mobile user. This high quality, space saving, 3 button mouse includes a built-in scroll wheel with hyper scroll allowing rapid scrolling by simply moving the mouse. The 1000 dpi optical sensor provides precise cursor movement for easy, smooth navigation. The sleek matt finish will bring style and improved performance for your high volume workload while traveling for business, at the office, or at home.
- V7 MV3030 - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 5.1 cm x 8.9 cm x 3.4 cm
- 50 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Retractable cable, scrolling wheel
- Cable Length
- 71.1 cm
- OS Required
- Apple MacOS X 10.0 or later, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Mouse
- 5.1 cm
- 8.9 cm
- 3.4 cm
- 50 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Cable Length
- 71.1 cm
- 1 x USB - 4 pin USB Type A
- RoHS
- OS Required
- Limited warranty - 2 years
