Looking to protect your iPhone 6 Plus from screen shattering impacts? The V7 shatter proof tempered glass screen protector with anti-blue light filter has a 9H hardness rating to protect from screen impacts while preserving the optical clarity and touchscreen responsiveness. The anti-blue light filter removes relatively strong and harmful blue rays emitted from the phone screen reaching the eyes and helps reduce eye strain and fatigue without visibility altering the color on-screen. The oleophobic coating is also fingerprint resistant and smudge proof. The edge of the screen protector is beveled so there are no sharp edges for safe use. The quick and easy bubble free installation is the perfect fit for your iPhone 6 Plus.
- V7 - screen protector for mobile phone
- Product Type
- Screen protector - glass
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, smudge-proof
- Package Content
- Cleaning cloth, screen protector, squeegee, wet cleaning wipe
- Product Material
- Tempered glass, silicone gel
- 6.9 cm 14.7 cm
- Thickness
- 0.05 cm
- 11 g
- 1-year warranty
- Product Type
- Intended For
- Mobile phone
- Protection
- Package Content
- Product Material
- 6.9 cm
- 14.7 cm
- 11 g
- Thickness
- 0.05 cm
- Anti-fingerprint, bubble-free installation, Oleophobic coating, Blue Light cut function
- 1 year
