Your basket is empty
V7 Compact Wireless Mouse - Blue
Quicklinx: BFKQWS00 Mfr#: MV3040-24G-BLU-15EB
The MV3040-24G compact-size optical mouse has a comfortable universal design with seamless point and click interaction. This high quality space saving 3 button mouse includes a built-in scroll wheel with enhanced tactile button and tracking feedback. The 1200 dpi optical sensor provides precise and swift cursor movement for easy smooth navigation. The professional finish will bring style and improved performance for your high volume workload at the home, office or while traveling for business.
V7 MV3040-24G - mouse - 2.4 GHz - white/blue
Mouse
Wireless - 2.4 GHz
White/blue
Orientation
Right and left-handed
5.5 cm x 10.2 cm x 3.6 cm
72 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1200 dpi
Scrolling wheel, power saving automatic sleep function, on/off power switch, Nano wireless receiver, anti-slip side panels
Apple MacOS X 10.x or later, Microsoft Windows Vista / XP / 7 / 8
Package Type
Retail
2 years warranty
Mouse
Wireless Receiver
Orientation
5.5 cm
10.2 cm
3.6 cm
72 g
White/blue
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
3
Movement Resolution
1200 dpi
1 x USB - 4 pin USB Type A
2 AAA batteries
FCC, RoHS, WEEE
Package Type
Retail
