Listen to your favorite songs from your Bluetooth enabled device through the crystal clear V7 Bluetooth wireless speaker. You will enjoy its 33 foot range, and hands-free speakerphone function allowing you to answer phone calls from your Bluetooth enabled mobile phone. Designed with a powerful 2 Watt wireless speaker, a built-in sub-woofer and bass vibration function. The USB rechargeable built-in battery, charges fully in 2-3 hours to provide up to 4 hours of uninterrupted sound while you\re on the go.
- V7 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Speaker Type
- Active
- Continuous Power
- 2 Watt
- Frequency Response
- 100 - 16000 Hz
- Amplifier
- Integrated
- Bluetooth
- Speaker System Details
- 1 x portable speaker 2 Watt - 100 - 16000 Hz
- Black
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - lithium polymer
- 6.35 cm x 6.35 cm x 6.35 cm
- 200 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Enclosure Colour
- Black
- Enclosure Material
- Silicone
Speaker System
- Speaker Type
- Active
- Continuous Power
- 2 Watt
- 100 - 16000 Hz
- Amplifier
- Integrated
- Bluetooth 2.0
- Bluetooth Profiles
- Hands-Free Profile (HFP)
- Transmission Range
- 10 m
- Controls
- Power on/off, volume
- Additional Features
- Surface vibration technology
- Speakers Included
- 1 x portable speaker - 2 Watt - 100 - 16000 Hz
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - lithium polymer
- Capacity (Ah)
- 400 mAh
- Run Time (Up To)
- 4 hour(s)
- 6.35 cm
- 6.35 cm
- 6.35 cm
- 200 g
- Limited warranty - 2 years
