V7 Bluetooth Portable Speaker -Black
Quicklinx: BC70WS00 Mfr#: SP5000-BT-BLK-9EC
Listen to your favorite songs from your Bluetooth enabled device through the crystal clear V7 Bluetooth wireless speaker. You will enjoy its 33 foot range, and hands-free speakerphone function allowing you to answer phone calls from your Bluetooth enabled mobile phone. Designed with a powerful 2 Watt wireless speaker, a built-in sub-woofer and bass vibration function. The USB rechargeable built-in battery, charges fully in 2-3 hours to provide up to 4 hours of uninterrupted sound while you\re on the go.
V7 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Continuous Power
2 Watt
Frequency Response
100 - 16000 Hz
Amplifier
Integrated
Bluetooth
Speaker System Details
1 x portable speaker 2 Watt - 100 - 16000 Hz
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
6.35 cm x 6.35 cm x 6.35 cm
200 g
Hands-Free Function
Enclosure Colour
Enclosure Material
Silicone
Speaker System
Speaker Type
Active
Continuous Power
2 Watt
Frequency Response
100 - 16000 Hz
Amplifier
Integrated
Bluetooth 2.0
Bluetooth Profiles
Hands-Free Profile (HFP)
Transmission Range
10 m
Controls
Power on/off, volume
Additional Features
Surface vibration technology
Speakers Included
1 x portable speaker - 2 Watt - 100 - 16000 Hz
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Power Source
Options
USB charging
Rechargeable - lithium polymer
Capacity (Ah)
400 mAh
Run Time (Up To)
4 hour(s)
6.35 cm
6.35 cm
6.35 cm
200 g
