Product
Brand
V7 Bluetooth Portable Speaker - Red
Quicklinx: BJG5WS00 Mfr#: SP5000-BT-RED-9EC
Listen to your favorite songs from your Bluetooth enabled device through the crystal clear V7 Bluetooth wireless speaker. You will enjoy its 33 foot range, and hands-free speakerphone function allowing you to answer phone calls from your Bluetooth enabled mobile phone. Designed with a powerful 2 watt wireless speaker, a built-in sub-woofer and bass vibration function.
V7 SP5000 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Nominal Output Power
2 Watt
Frequency Response
100 - 16000 Hz
Amplifier
Integrated
Bluetooth
Red
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
200 g
2 years warranty
Hands-Free Function
Enclosure Colour
Red
Speaker System
Speaker Type
Active
2 Watt
Frequency Response
100 - 16000 Hz
Amplifier
Integrated
Bluetooth 2.0
Bluetooth Profiles
Hands-Free Profile (HFP)
Transmission Range
10 m
Controls
Power on/off, volume, call answer
Additional Features
LED indicators
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Power Source
Options
USB charging
Rechargeable - lithium polymer
400 mAh
Run Time (Up To)
4 hours
200 g
