The V7 USB 2.0 flash drive with retractable connector features an easy to use, slide-out design that will keep your USB connector free of dirt and dust, keeping your data safe. Store loads of files, and take them with you wherever you go, with a range of size options to choose from.
- V7 VU264GDR-BLK-3E - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 64 GB
- Enclosure Colour
- Black
- OS Required
- Apple MacOS 9.x or later, Linux Kernel 2.4 or later, Microsoft Windows 98/2000/XP/Vista/7/8
- 5 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Enclosure Colour
- Black
- Compatibility
- Non-specific
- Read Rate
- Up to 15 MB/s
- Write Rate
- Up to 5 MB/s
- Interface Type
- USB 2.0
- Dustproof, retractable connector, dirtproof
- Plug and Play, FCC, RoHS, WEEE
- OS Required
- Limited warranty - 5 years
- 20 mm
- 10 mm
- 56 mm
- 14 g
