Your basket is empty
V7 64GB USB 3.0 Flash Drive - Black
Quicklinx: BDQDWS00 Mfr#: VU364GDR-BLK-3E
The V7 Slider USB 3.0 Flash Drive features a retractable, slide-in/out design that will keep the connector free of dust and dirt, plus it has an impact-resistant locking slider, so you can be sure it will stay connected when you plug it in. The Flash Drive is made for maximum portability with a key-ring friendly design, and data transfer is a snap with read / write speeds of up to 80MB/s and 25MB/s.
V7 VU364GDR-BLK-3E - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Enclosure Colour
5 years warranty
USB flash drive
Storage Capacity
64 GB
Enclosure Colour
Compatibility
Non-specific
Read Rate
Up to 80 MB/s
Write Rate
Up to 25 MB/s
Interface Type
USB 3.0
Dustproof, retractable connector, key ring loop, dirtproof, impact-resistant
FCC, RoHS
Limited warranty - 5 years
10 mm
20 mm
55 mm
14 g
