Upgrading the memory in your desktop or notebook is one the most cost effective ways to boost performance. Memory upgrades are quick and easy to install. Adding extra memory ensures that the operating system and applications run faster and smoother and is essential for applications such as gaming, HD video and image editing, graphic design, multi-tasking and manipulating large amounts of data. Upgrading is also an easy way of extending the life of your system
- V7 - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3L SDRAM - SO-DIMM 204-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3L-12800)
- Low Voltage, unbuffered
- Voltage
- 1.35 V
- 10 years warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Module Height (inch)
- 1.18
- Speed
- Non-ECC
- Voltage
- 1.35 V
- RoHS, WEEE
- 10 years warranty
