Your basket is empty
V7 4GB DDR3 SODIMM 1333MHZ CL9
Quicklinx: BCPZWS00 Mfr#: V73V4GNZBII
Upgrading the memory in your desktop or notebook is one the most cost effective ways to boost performance. Memory upgrades are quick and easy to install. Adding extra memory ensures that the operating system and applications run faster and smoother and is essential for applications such as gaming, HD video and image editing, graphic design, multi-tasking and manipulating large amounts of data. Upgrading is also an easy way of extending the life of your system
V7 - DDR3 - 4 GB - SO-DIMM 204-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Unbuffered
10 years warranty
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
10 years warranty
