Upgrading the memory in your desktop or notebook is one the most cost effective ways to boost performance. Memory upgrades are quick and easy to install. Adding extra memory ensures that the operating system and applications run faster and smoother and is essential for applications such as gaming, HD video and image editing, graphic design, multi-tasking and manipulating large amounts of data. Upgrading is also an easy way of extending the life of your system
- V7 - DDR3 - 4 GB - SO-DIMM 204-pin
- Product Type
- RAM memory
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1066 MHz (PC3-8500)
- Latency Timings
- CL7
- Unbuffered
- 10 years warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL7
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
- 10 years warranty
