The V7 Slider USB 3.0 flash drive features a retractable, slide-in / out design that will keep the connector free of dust and dirt, plus it has an impact-resistant locking slider, so you can be sure it will stay connected when you plug it in. The flash drive is made for maximum portability with a key-ring friendly design, and data transfer is a snap with read / write speeds.
- V7 VU332GDR-BLK-3E - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Enclosure Colour
- Black
- 5 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Enclosure Colour
- Black
- Compatibility
- Non-specific
- Read Rate
- Up to 70 MB/s
- Write Rate
- Up to 20 MB/s
- Interface Type
- USB 3.0
- Dustproof, retractable connector, key ring loop, dirtproof, impact-resistant
- FCC, RoHS
- Limited warranty - 5 years
- 10 mm
- 20 mm
- 55 mm
- 14 g
